I bought an unlocked PCM and a Trinity for my 2016 charger 3.6L and there is only one Tune, the Modified Stock Tune and I cannot adjust the parameters. Where are the rest of the options mentioned on the Web site listed below.
•93 Octane Performance Tune: 15HP 20TQ
•91 Octane Performance Tune: 13HP 15TQ
•Calibrate Speedometer for Gear Ratio
•Calibrate Speedo for Tire Size
•Cooling Fan Control
•Throttle Booster
•Fuel Rich/Lean Adjustment
•Spark Timing Advance/Retard
•Idle RPM
•Top Speed Limiter
•Rev Limiter
Chuck
2016 Charger one tune on the trinity???
Re: 2016 Charger one tune on the trinity???
load this update to the tool then you should see the tunes.capcas wrote:I bought an unlocked PCM and a Trinity for my 2016 charger 3.6L and there is only one Tune, the Modified Stock Tune and I cannot adjust the parameters. Where are the rest of the options mentioned on the Web site listed below.
•Throttle Booster
•Idle RPM
•Top Speed Limiter
•Rev Limiter
Chuck
- trinity_diablo_dcx_gas-1r13f_update.crom
- (11.18 MiB) Downloaded 285 times
tech@diablosport.com
I will download and test
thanks
thanks
I don't have the same issue, but am still a bit confused. I now have the canned 93 tune, but can't change my rev limiter, gear ratio, fan control or top speed. Am I correct or missing something? I like the canned tune but would like to set some shift points to get more accuracy at the track. I also know that shift points are different when in sport mode. Can I adjust these per mode?
If we can't change any of these items when using the canned tunes, then what good is changing the rev limiter and top speed with a stock tune? Happy with product so far, but am now starting to feel a bit as if my hands are tied.
there is no shift point adjustment available for these vehicles currently. TCM support is in the works.Ken Sheaffer wrote:I don't have the same issue, but am still a bit confused. I now have the canned 93 tune, but can't change my rev limiter, gear ratio, fan control or top speed. Am I correct or missing something? I like the canned tune but would like to set some shift points to get more accuracy at the track. I also know that shift points are different when in sport mode. Can I adjust these per mode?
