Hi there,
I just want to make sure i have the latest software version for the Trinity T1000 .
Current Version: v.31r13a
I was told v.31r13K is the newest?
However when I download the file from your site and try to install it, it says that, that file is older and need a password to install...
TOOL INFO:
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6OCLGB7-3'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r13a 09/18/2014 12:01:54 PM boot4'.
Vehicle VIN = '1B3ES66SX3D181571'.
Vehicle Calibration = '04510055AE'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 1
Marriage VIN : 1B3ES66SX3D181571
Tool ID :
Desc :
PCM : 04510055AE
Multi ECU Tuning : 1
Name: PCM, TuneID: gas reva 1025cc 3bar, Modified: yes, Lock: No, Erased: No
Server:
Trinity T1000 latest update?
05 Dodge Neon SRT4
Re: Trinity T1000 latest update?
Lets start here...does the device work properly on the current software?
if so, my honest advise is to leave it alone
tech@diablosport.com
Yes the device seems to be fine the only issue I have is my car is running a little too rich and already taking out 12% fuel get me around a 10.8afr under work.
I know the tune I have is designed to run a little Rich for safety
But I'm wondering if me changing the values is actually changing anything.
Besides everyone always wants the latest and greatest updates even if it is just compatibility with newer vehicles
05 Dodge Neon SRT4
Gotchya.
Most of the later updates for the T1000 were simply to add support for new cals, there were very few fixes or new 'stuff' added, so I would suggest leaving it as is.
The tune running rich would be specific t the way that tune is set up. Leaning it out through the params should work as long as the tune was set up properly to start with.
