o6 Dodge cummins 5.9 4x4 EPP stacked with predator
Guys I need some help. Im about to yank the dang puck off my truck! You havent supplied much info about the thing. I know you recommend large diameter exhaust and upgrade intake for performace settings with the predator and a built tranny 4 the most extreme setting. I didnt see any recommended upgrades needed for the puck, as far as fuel system, I mean. My question is whats the highest puck stack setting I can run without damaging my truck from too much fuel pressure? I had some other questions on the forum, but I guess they werent read.
Lotta ?s about extreme power puck.
RE: Lotta ?s about extreme power puck.
as long as you are running a stack tune they should have the fuel pressure set for safe operation as far as fuel components. If you run a non-stack tune while stacking the puck then you will have some high pressure.
Other than that your only concerns should be the transmission and EGT's.
concoursd! Many Thanks! I was starting to regret buying the puck, and my opinion of DiabloSport was wavering. I truly appreciate your prompt and informative answers.
if you ask for more pressure than the system can provide, it wont hurt anything, it will just stop making more power...
tech@diablosport.com
