Can I run my D7159 with the Quadzilla Mileage Max? How about the D7159 with
a boost fooler? 2006 Dodge Ram 2500 w/ Cummins TD.
thank you
D7159 and Mileage Max?
RE: D7159 and Mileage Max?
Boost fooler, yes, not so sure bout the mileage thing, what is it exactly?
Is it OBDII based, or plugs in under the hood?
tech@diablosport.com
Its an underhood plug and play module. Connects between MAP sensor, fuel rail pressure, and coolant temp sensor. Advertises
8-12% mileage increases. Quadzilla Max Mileage Module. So it would be inline with power puck just like boost fooler would be.
No, I dont know if thats a good idea.
So if I install my Quadzilla boost fooler ahead of my D7159 at the MAP sensor will everything function
like it should? ie: lowering my EGT's while my puck does its thing?
yes...
