Ford 6.4 instructions
I have just received the Extreme Power Puck for 2010 Ford F250 Super Duty 6.4 Diesel... Although the instructions were not in the manual, I did find one page here that explains little... Please describe P3020 installation, especially the extra cable with the sensor (what is it?) This cable plugs into the Cable that plugs into the puck...? Thank you!
RE: Ford 6.4 instructions
tech@diablosport.com
Re: RE: Ford 6.4 instructions
Thanks... but, I did find that one page information sheet that did not explain what the extra cable is... Do you have any other knowledge of what this sensor is for... looks like a pressure sensor? Is it a fuel pressure sensor? Does it just plug in to something? Specific information would be great!
RE: Re: RE: Ford 6.4 instructions
ok, that was funny... I understand... this is the first one I have seen. It is not a sensor!!! It is the diablo dial...on a wire. crap! Funny thing is I do not feel stupid ... just look it.
Thanks for your understanding...
Should I install and start the truck with the dial turned all the way left... or does it matter? Someone else said their truck produced a fuel pressure code, they reset the code and started with the puck turned all the way off an then it was ok. Does this make any sense or does it matter?
you ca start it with the dial anywhere you;d like
