Board index General Technical Support MAF.i.a 95 mustang gt with 96 up mass air meter
MAF.i.a Support
Post Tue Oct 13, 2009 8:51 am
I changed my stock meter and harness to the newer style does it make a difference if i order the 96 up mafia or should i get the 95-88 mafia? and change my pigtail back? just cureous if there are any interferances in programming or is it the same and just the paigtails are different thanks
will this help me with the maf making the car run rich and searching for idle?
I'd check with your tuner as to what to order based on the MAF you will be using.
The Mafia will require custom tuning.
561-908-0040x4
Return to MAF.i.a
cron
