CMR Does not Disable P000B
Re: CMR Does not Disable P000B
Mike,
I just plugged my trinity to my PCM and there are no codes.
A 4 banger has more power than my v8 hemi. Just to give you an idea how my vehicle is running.
I will have my car dynoed to see how it responds or any changes. I will update as soon as I get the results.
it hasnt been tuned on a dyno with the cam install?macedo6466 wrote:I will have my car dynoed to see how it responds or any changes. I will update as soon as I get the results.
tech@diablosport.com
Mike,
Yes, it has... My vehicle has been through months of cmr therapy. Plus it has been Dyno tuned twice. At the the time I had a P000B trouble code.
Unfortunately the Dyno was already booked for the week. Instead I had a wideband 02 sensor install. The LC2 from innovate. Results: at idle fluctuates from 14.5 - 15.0 and cruising speed it' s the same. I have to say that the air/fuel ratio is pretty good. I'm now hesitant about conducting a Dyno test knowing that my air fuel ratio is correct. I don't think a Dyno tune would help at this point.
Mike,
Wanted to keep you updated.
It worked!
Thanks again Mike.
It worked!
Thanks again Mike.
OK?
What worked?
What worked?
The disabled P000B check engine light
The vehicle is now responding to any updated custom tunes
I upload to the PCM.
Oh, ok, good.
I thought you said it worked initially, then it didnt, so I was not sure
Mike,
The P000B is haunting me again..
This happened as soon as I updated my trinity.
I was required to updated my Trinity to the "1r13c Crom" in January time frame.
(Previously I think I had the 1r12 Crom on my Trinity and the P000B was deleted worked great.)
My CMR tuner has been having trouble getting rid of the P000B code.
I get the P000B when when getting readings from diagnostics /OBDII.
There is no embarrassing CEL light on. which is really good.
What do you think?
Any suggestions?
What do you think?
Any suggestions?
I've might of spoke too soon...
My tuner just sent me an updated tune to disable the P000B.
it worked..
it worked..
Hello guys
I have the same problem the p000b can not be disabled and when I disable it the check engine light off but the vvt will not work
Any advice ?
Any advice ?
I am having the same problem on my Scat Pack Shaker. No engine light. Just the stored code. How do I disable it? I have a custom tune. Thanks!
you have to work with your cmr tuner to have it disabled in the custom tune.
