Board index (Legacy) Predator Technical Discussion Predator GM Gas 2003 GMC Sierra electric fan swap
Moderators: mikel, 06MonteSS
Post Sun Jun 08, 2014 3:49 pm
I have a 2003 GMC Sierra 2500. I installed 05 electric fans and am using a switch in the heater hose. I'd like to have the pcm activate the fans like factory 05's. I'm using a predator U7193. Can you help me?
Shootin for the moon
Post Sun Jun 08, 2014 3:50 pm
Also, I have a 160 thermostat installed.
Post Sun Jun 08, 2014 4:21 pm
Here's my tune files if you get a chance.
ar12579405cua.grg
(312.11 KiB) Downloaded 203 times
AR12579405CUA_custom.grg
(6.25 KiB) Downloaded 230 times
Post Thu Jun 12, 2014 6:08 pm
Just curious if anyone has given this a look
Post Fri Jun 13, 2014 8:58 am
not sure how i missed this, but here you go, sorry for the delay.
ar12579405cua_fans.grg
(248.1 KiB) Downloaded 222 times
561-908-0040x4
Post Fri Jun 13, 2014 9:25 am
Thank you very much. I figured you guys were probably busy.
Post Fri Jun 13, 2014 9:47 am
I haven't used the predator in a while. When I plugged it into my truck, it powered up, let me select the custom tune, and then said "The tune file was not installed to vehicle, error (). It's got me baffled. I send the files from the computer to the tool first.
Post Fri Jun 13, 2014 9:54 am
got a stereo installed?
anything thats been installed since last time you flashed it?
561-908-0040x4
Post Fri Jun 13, 2014 9:55 am
I had an aftermarket in it before, but I have replace it with a new one a month ago.
Post Fri Jun 13, 2014 9:59 am
My volt meter is reading at the line between 9 and 14. Do you think the voltage is too low?
Post Fri Jun 13, 2014 10:01 am
I just remember I installed a remote start after I flashed it.
Post Fri Jun 13, 2014 10:18 am
its somethign wired into the trucks harness causing the issue.
if there is a stereo, its the aftermarket adapter harness, unplug that from the vehicle harness.
If remote start, disconnect it from the vehicle harness.
561-908-0040x4
Post Fri Jun 13, 2014 10:28 am
It was the remote start. I unhooked it and the tune loaded perfectly. Thanks for the help, I really really appreciate it.
Post Fri Jun 13, 2014 10:31 am
sweeeet.
561-908-0040x4
Post Fri Jun 13, 2014 10:38 am
I forgot my remote start hooks up to the datalink in the obd2 port. That probably didn't help anything.
Next
Return to Predator GM Gas
