Board index (Legacy) Predator Technical Discussion Predator GM Gas 2003 GMC Sierra 2500hd e fan question
Moderators: mikel, 06MonteSS
Post Fri Jul 04, 2014 9:03 am
Hi, you guys set up my electric fans on my Sierra. They don't want to come on with the a/c at all. You did tell me it was all set at stock value. I installed the stock tune and started fresh with everything and it still doesn't want to work. I'll post up my tune and hopefully you guys can help me.
Thanks,
Roman
AR12579405CUA_custom.grg
(6.25 KiB) Downloaded 124 times
ar12579405cua.grg
(312.11 KiB) Downloaded 127 times
ar12579405cua_fans.grg
(248.1 KiB) Downloaded 122 times
Shootin for the moon
Sorry for the delay, try this.
ar12579405cua_fans2.grg
(248.1 KiB) Downloaded 128 times
Okay, installed the new tune and pin 33 on my pcm still isn't grounding. Is it possible my pcm won't do this?
Post Thu Jul 10, 2014 12:13 pm
Everything is set up in the tune just as a factory e fan vehicle would be. If you're still having issues with it I would suggest maybe going to a standalone fan controller.
I've done some research and apparently have some pressure issues with my truck, so off to the a/c man to get it fixed. I do appreciate your help, definitely love what the tuner has done for my truck.
Glad you hear you're loving the tuner, let me know if I can help any further.
Return to Predator GM Gas
