Board index (Legacy) Predator Technical Discussion Predator GM Gas Speedo off fixed
Speedo off fixed
Moderators: mikel, 06MonteSS
Post Fri May 12, 2017 5:27 pm
Ok things were good then I modified predator tune turning off egr and air and increased mph in 1st at normal to etc and now Speedos 50% fast!
I might have gone into ratio and re entered the 3.73 ratio but it was already in there
When I check now Ratio and tyre size is correct
2000rpm in drive shows 60mph instead of about 40!
Help!
Thanks scott
Post Sat May 13, 2017 3:44 pm
Got it fairly accurately now but had to set gears to 5:13 will this have any negative impact?
Post Mon May 15, 2017 4:13 am
As i was getting no advise decided to remove predator tune, then with original back on speedo was correct.
Reloaded the predator tune and now its ok , checked the gears was correct at 3.73
Went into the tyre size and it originally comes up 00's in all fields so I recon adding the correct sizes here must have messed up the speedo readings -guess this field doesn't work properly.
Return to Predator GM Gas
