Board index (Legacy) Predator Technical Discussion Predator GM Gas 7194
7194
Moderators: mikel, 06MonteSS
Post Wed Sep 27, 2017 2:00 am
Hello
I have a 7194 ,tried to update and now having all sorts of problems.It is currently stuck on launching app and wont do anything else.
I have tried many times to update the crom u7194-9r10.crom, I would leave the programmer unplugged from the power source ,open dsdownloader choose the right com port ( usb to rs232) load the crom and then power up the programmer.
It sometimes goes to "installing bootloader" but sometimes not it just goes through its booting up until it reaches launching apps and then gets stuck there.
But when i am able to get to installing bootloader ,dsd loads up the crom then dispalys the window showing writing packets and after done a window pops up with the following
I did not see the tool on the selected port
is the tool connected
is the serial port selection correct
is the tool powered up and waiting at the main menu screen
I have tried 2 different cable and 2 different computers with the same results.
Any advice
THanks
Post Wed Sep 27, 2017 12:15 pm
try loading this, let me know if it reboots properly at the end.
Dont try to use it yet if it does.
u7194-9r07.crom
(748.98 KiB) Downloaded 440 times
561-908-0040x4
Post Wed Sep 27, 2017 11:01 pm
HI
Unfortunately the exact same thing happens
It's stuck on launching app...
Is there anything else I can try ?
Post Thu Sep 28, 2017 11:39 am
I dont have any other thoughts unfortunately.
Might be time to consider upgrading that device and trading it in.
561-908-0040x4
Post Fri Sep 29, 2017 3:28 am
Is this a software problem?
It was working fine before the update
Post Fri Sep 29, 2017 9:12 am
what version was on it before you decided to update it?
561-908-0040x4
Post Sat Sep 30, 2017 12:06 am
Hi
It had 9r07
Post Wed Oct 04, 2017 1:37 am
Do you have any other suggestions?
Post Wed Oct 04, 2017 11:29 am
Not much else I can offer here unfortunately.
These devices have been out of production for about 6-7 years at least, and I have no way to resolve issues on older products.
We will let you trade it in for a credit toward a new tuner if you'd like to go that route.
561-908-0040x4
Post Wed Oct 04, 2017 11:35 pm
How much credit would I get towards a predator 2?
thanks
Post Fri Oct 06, 2017 3:27 pm
I am not 100% sure, but its a solid discount. Close to $100 off.
561-908-0040x4
Post Mon Oct 09, 2017 5:04 am
So what do i need to do to get the credit ?
Post Mon Oct 09, 2017 10:04 am
call our sales team, 561-908-0040x5
561-908-0040x4
Return to Predator GM Gas
