Board index (Legacy) Predator Technical Discussion Predator Ford Diesel 110 safe for mostly stock truck
Post Tue Jan 11, 2011 3:19 pm
I loaded the 85, lots of codes, seems like others have had issues with the 85 as well. was going to load the 110. I have 4" turbo back along with a napa filter mod.
is there anything i need to worry about with the 110 tune?
injectors, oil pump, etc... or should i be fine to load and launch!
2002 7.3L F250 Crew 4x4
2011 5.0 Mustang GT - 10.81@128.6
Post Tue Jan 11, 2011 3:36 pm
truck has 107k btw,
Post Tue Jan 11, 2011 3:42 pm
If driven with a right foot that is connected to a sane brain, yes, perfectly safe, and should even yeild pretty good mileage.
561-908-0040x4
Post Tue Jan 11, 2011 10:49 pm
my buddy loaded his 01 today and got some pinging on the 110. probably stick with the 85
Post Wed Jan 12, 2011 1:00 pm
some cals are more prone to injector rattle than others, it could also depend on how well the truck has been maintained.
Id try it just to see ;)
561-908-0040x4
Post Wed Jan 12, 2011 1:02 pm
doh, i might.
funny thing is, his hasn't thrown one code on either tune, and mine throws the 1211 every time
Post Thu Jan 13, 2011 1:50 pm
So, i gave it a shot today. Felt real good at light and part and up to about 80% or so tps. At WOT, i got the injector rattle pretty good.
My question would be, for everyday driving. I really don't "wot" the truck.
So, Is what you meant by "sane brain" driving the truck on that tune, but no WOT?
Last questions. Will I get better mileage out of the 110 tune, than the tow or 85 if I am not running it out?
What would be needed to run the truck out on the 110. A better HPOP or injectors, or both?
by sane brain, I meant, not hot rodding it all over the place, lol.
More pump would likely help with the 110 tune more than anything else.
561-908-0040x4
Which tune will net the best mileage?
ideally, the 110 can provide the best mileage due to the amount of timing added.
561-908-0040x4
Return to Predator Ford Diesel
