Board index General Technical Support DataViewer Transmission Temp
Transmission Temp
Post Fri Dec 04, 2009 2:18 am
What PID is this called? I selected the one that says "TRANS TEMP? but it just stays at 40 all the time, there must be another one somewhere? Thanks
2006 Dodge Ram 5.7 Hemi
Custom tune from Procharger
Post Fri Dec 04, 2009 10:03 am
Are you refering to "J1850 TRANS OIL TEMP" on the J1850 node in DV? Please record a log with the PID (about 5 seconds worth is sufficient) and runtime.txt found in My Documents\Dataviewer. Either postup or email it to
Post Tue Dec 16, 2014 8:25 am
Tried to check the transmission temp on my 300c srt8 2006 today using the "J1850 TRANS OIL TEMP" PID. Same thing happened to me. Showed -40C and didn't change as the engine got warmer.
Post Sun Jun 04, 2017 8:03 am
у меня по коробке пишет такую вещь
1 Fault Found:
17095 - Transmission Fluid Temp Sensor G93: Implausible Signal
P0711 - 35-10 - - - Intermittent
что этото и как с этим боротся
Return to DataViewer
