data viewer use on surface
I'm wanting to use my Microsoft Surface to view my data logs. I already have the logs saved to the Surface. However, when I try to download the data viewer I get a message that says the program won't work on my PC. Is the data viewer compatible with the Surface or am I doing something wrong? If it's not compatible, is there a chance that this could be made available in a format that would work with the Surface? Thanks in advance for your help with this.
Re: data viewer use on surface
not compatible with a tablet.. have to use a Windows PC or Laptop...
and no it won't be... there's a lot of required drivers, c++ supporting drivers, etc that the programs need, which wouldn't run on a surface..
need to use a PC or Laptop...
it will work on a tablet with full windows 7/8/8.1, I've seen it.
Not RT.
Not RT.
tech@diablosport.com
yeah, that's with a FULL normal PC version of windows..
So I take it that jailbreaking my Surface isn't going to allow it to do this. Is that right?
