Board index Trinity Technical Discussion Trinity Ford Gas 2015 F150 Ecoboost not working.........
Post Tue Nov 03, 2015 8:30 pm
I had the trinity married to my srt8 jeep, i set it back to stock then updated the trinity via the newly downloaded dsdownloader. From there i changed the vehicle to the ford f150 and put it into the truck. then it stated it needed a calid update so i rehooked it to the dsdownloader. then it worked and installed the tow tune and was completed. i started the truck and went to go somewhere but it would do nothing but start/idle and even hitting the gas pedal there was no revs even when the gear selector was put into neutral.
i did put the original backup tune in and truck works great, i did not try to install any of the other tunes as i needed to use the truck.
oddly enough there was no option for the mpg tune, just was the tow/93/91/87 and modify stock file
it appears you have one of the cal ids that are effected by dead peddle. we have thread going already full of information. we are very close to having this fixed. post up in there :)
viewtopic.php?f=16&t=51870
fix attached!!
update tool with this crom then reload the tunes :)
trinity_ford_can_gas-1t13la_update.crom
(3.85 MiB) Downloaded 137 times
561-908-0040x4
will this work for all tune files?
update didn't work, instant dead pedal, here are the original backup and the one that was installed
PCM_PKCMAK4_DiabloSport_Towing.frg
Diablosport 87 octane tow tune
(9.25 KiB) Downloaded 131 times
PCM_PKCMAK4.frg
original backup
(193.41 KiB) Downloaded 114 times
Here you go this should fix it.
trinity_ford_can_gas-1t13lf_update.crom
(3.86 MiB) Downloaded 133 times
Insert Clever comment here...
even the towing tune will give the 50hp/70tq bump in power correct or will it just adjust transmission shifting?
it bumps the power too
:mrgreen:
:mrgreen:
yeeeeeeeeeeeeep sure does, i know some tow tunes adjust shifting but yeah, noticeable difference for sure
cheers!
Return to Trinity Ford Gas
