cat convertor monitor temps
When monitoring cat temps on my 2013 ford 150 3.5 L ecoboost using the latest update the values displayed are 10 times what they should be. Why is this so? All other monitors seem to work well.
Re: cat convertor monitor temps
can you log it and post it up here?
tech@diablosport.com
Will do ASAP. Thanks Mikel.
Mikel;
Attached log as requested.
- 2013_CAT_TEMP.LOG
- Cat temp log in Celsius
- (42.04 KiB) Downloaded 512 times
Yeah, those values do not seem correct, I'll get it looked into.
Thanks Mikel. I see it recorded in Fahrenheit not Celsius. I am new at this so I see if you make a change on one layout it becomes the default. My apologies.
Mikel;
Any updates on this monitor?
No, our team is still investigating.
Any progress from the team on this issue?
Alright this should fix it. Unzip and load it here: C:\Program Files (x86)\Common Files\DiabloSport\DataViewer
- diags.zip
- (8.39 MiB) Downloaded 527 times
Insert Clever comment here...
I applied the file as directed. Did a full update to latest cron. The tool still reads 10x what it should be in Fahrenheit degrees. Did I miss something?
No I did. I was looking at the wrong units.Yiggy wrote:I applied the file as directed. Did a full update to latest cron. The tool still reads 10x what it should be in Fahrenheit degrees. Did I miss something?
- diags.zip
- (8.39 MiB) Downloaded 515 times
The fix works well using dataviewer. Will it correct the Trinity tool when connected to DS downloader so that monitors display correctly for cat temps?
Looking for answer to question posted March 31. Please advise. Thanx.
No the firmware would have to be rebuilt for that to change. We're transitioning servers currently so might be a couple weeks for any new builds.
