I have a 2006 F150 5.4 Fx4 with 37" tires and a 4.56 rear end, when selecting my gear ratio under parameters I can only select 4.52. Am I missing something? I tried using both large and small increment buttons and occasionally the last digit will change to a 3 (allowing me to then select 4.53) or it rarely changes to a 9 (allowing me to get 4.59) this is driving me nuts!!! Second: what is "NOV adjust"? Third: I can't change my gauges under engine monitor. Every time I select an "undefined gauge to customize it just changes the page. How do I make and save a custom gauge layout? Fourth: How does one get a custom tune for max fuel economy? are the pre loaded tunes my best option?
Thanks!!
Can't fine tune axle ratio. plus other issues/questions
Re: Can't fine tune axle ratio. plus other issues/questions
4.52 should be fine, but if you export the last tune written and send it over or post it here I can set it to 4.56 for you.
What version is the tool on (options/show information)
tech@diablosport.com
