Board index Trinity Technical Discussion Trinity Dodge Gas Caliber SRT4 WOT BOX Causing limp mode
Post Fri Oct 25, 2019 7:30 pm
I'd like to run my WOT BOX with the canned 93 tune for now till I get a custom tune. What can I do to allow the tune to not send the car into limp mode when I activate 2 step and WOT shift?
2008 Caliber SRT4 #1547
Post Tue Oct 29, 2019 11:58 am
load the tune then post the last tune written file here.
561-908-0040x4
Post Wed Oct 30, 2019 10:15 am
Do you need my backup as well?
Post Wed Oct 30, 2019 11:46 am
Heres my backup tune and the 93 tune that I will be using.
Thanks!
PCM_05187661AF_Perf_93oct.drg
(3.25 KiB) Downloaded 128 times
PCM_05187661AF_Backup.drg
(781.16 KiB) Downloaded 126 times
here you go
PCM_05187661AF_2step.drg
(573.77 KiB) Downloaded 120 times
561-908-0040x4
mikel wrote:
here you go
Ok so I installed the tune. As soon as I 2 step, check engine light comes on and goes right into limp mode still... am I missing something?
Not sure...post the last tune written please.
what was the code?
561-908-0040x4
what was the code?
Heres the last tune written, I'm using a trinity if that changes anything. Codes are P2302, P2305, P2308, and P2311 all for the ignition coils. I appreciate all the help.
PCM_05187661AF_pcm_05187661af_2step.drg.drg
(1.25 KiB) Downloaded 118 times
you didnt load it properly.
You selected the same tune as the tune to load and as the backup.
You must select a copy of the stock tune as the backup when prompted so the tool can see the differences and send them to the device.
561-908-0040x4
Post Thu Jul 02, 2020 10:12 pm
Hi, I have a Diablosport Trinity on the 93 octane tune. I am having the same problem with the N2MB WOT box 2 step feature. DTC codes are P2302, P2305, P2308, P2311, P0300. Any help would be appreciated! Thank you! Attached are my backup and current tune files.... Please let me know if any other info is needed.
PCM_05030394AM_Perf_93oct_modified.drg
(3.25 KiB) Downloaded 32 times
PCM_05030394AM.drg
(781.01 KiB) Downloaded 25 times
Post Mon Jul 06, 2020 11:09 am
here you go.
PCM_05030394AM_2_step.drg
(573.7 KiB) Downloaded 25 times
561-908-0040x4
Thank you, I'll let you know if any other issues.
Return to Trinity Dodge Gas
