trinity for srt 4 questions
Like the title says. do the AEM wideband and guage with the trinity work together? and with the trinity can i adjust the A/F ratio? sorry if these are dumb questions... just tryin finish my parts list so i can order my stuff. thanks
RE: trinity for srt 4 questions
I don't think the AEM unit has analog output, only serial. The Trinity currently only supports analog input, but there is a serial connector on the back that will eventually allow for serial communications.
You can't adjust air/fuel ratio directly with the Trinity, but you can add/remove fuel, timing and boost with the Trinity, which should fit your needs for a mostly stock car. If you have a lot of mods, you will need to get a custom tune from a CMR dealer.
AEM has an analog output...it's what I use
I have the EUGO on my Trinity.. You just have to wire it up with an analog input plug and plug in the numbers for the settings.
