Cruise Not Working 05 1500 Hemi
HELP!! after i adjust the tire size on my 2005 ram 1500 my cruise control will not set over 30 mph. Talked to a diablo sport tech guy today and he gave me an email address that doesn't work(bferraro@powertech.com) to send my original backup and current tune.my case # was 298175
- original backup.drg
- orig tune
- (40.42 KiB) Downloaded 200 times
- PCM_56028958AI_Perf_91oct_modified.drg
- current tune
- (4.25 KiB) Downloaded 173 times
Re: Cruise Not Working 05 1500 Hemi
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6OALVA8-3'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r13k 05/11/2016 08:57:38 PM boot4'.
Vehicle VIN = '1D7HU18D35S301934'.
Vehicle Calibration = '56028958AI'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 2
Marriage VIN : 1D7HU18D35S301934
Tool ID :
Desc :
PCM : 56028958AI
PCM : 05094258AD
Multi ECU Tuning : 1
Name: PCM, TuneID: Perf 91oct, Modified: yes, Lock: No, Erased: No
Server:
Tool ID :
Desc :
PCM : 56028958AI
PCM : 05094258AD
Server:
