Board index Trinity Technical Discussion Trinity Dodge Gas Jeep grand cherokee 2007 fan control
Post Sun May 21, 2017 5:11 pm
Dears
I have Jeep GC WH 5.7 2007 which has hydraulic cooling fan. I installed 180 thermostat and I need to set the fan set points to lower degree. It seems that the trinity fan control is missing for this particular model. some guys said that it can be adjusted by HP tuner application by setting the fan type to PWM and then set a parameter "desired engine temperature" to the desired degree. the stock setting is 103 Celsius and I want to change it to 95.
I own the Trinity and I hope it can support this feature.
Post Tue May 23, 2017 12:16 pm
so is it a mechanical fan or electric?
Post the backup and last tune written files from your device please.
561-908-0040x4
Post Tue May 23, 2017 4:39 pm
It is mechanical rotating by the power steering fluid pressure. but the ECU controls the solenoids to control the speed.
PCM_05094636AG_Perf_91oct_modified.drg
Current tune loaded
(3.25 KiB) Downloaded 227 times
PCM_05094636AG.drg
Original Backup file
(84.6 KiB) Downloaded 214 times
Post Wed May 24, 2017 8:22 am
the fan settings are all lowered quite a bit in the tune, so if thats not affecting the fans its not likely something that can be controlled in the same manner as the electric fans.
561-908-0040x4
Post Thu May 25, 2017 3:22 am
Dear Mikel
Thanks for your feed back. the following is a reply from a jeep owner on other forum. he is describing how he solved the issue. I hope that can help finding a solution.
At last got my Jeep's hydraulic fan to now work as I want.
Used HP Tuner and set the low, med/high activation temps etc, but still did not go to high speed when reaching 100 C as set.
Today went back to the guy who does my tuning and found following:
three hydraulic fan types:
1. two speed
2. three speed
3. pulsed modulated
My Jeep has the pulsed modulated and thus the low/high temp limits are not the controlling settings. There is a selection where the required engine temp must be set, then the fan will attempt to maintain this set temp. Fan speed ramps up to full speed if required to keep this set temp.
The default on my Jeep was 103 C. Brought this down to 95 C and now works like a charm.
Post Thu May 25, 2017 7:38 am
let me see what we can find on this.
561-908-0040x4
Post Sun Jun 18, 2017 8:05 pm
Hi Mikel
did you find any way to solve this issue?
Post Wed Jun 21, 2017 9:18 am
Nothing yet unfortunately.
561-908-0040x4
Post Wed May 01, 2019 8:56 am
any word on this? i am running into the same issue and i really would hate to switch over to hp tuners since diablosport is so user friendly.
_______________________________________
2010 Jeep Commander Limited 5.7 2wd
CAI, 6.4 intake manifold, obx long tubes, custom catback, UPR catch can
Jay Greene tuned
eibach lowering springs on 20x10 SRT spider monkey's
Return to Trinity Dodge Gas
