Version: 1r13g
ValID: 68057155AF
I completed the version upgrade and calibration today using DSDownloader. I can not modify any tunes. Error quotes "parameters for this vehicle/transmission combination not available (4)". Also when I go to the performance menu it goes straight into the diablo tunes. There is no quick adjust option. Tunes available are 93, 91, and 87 Oct tunes as well as MPG booster, crawl, modify stock tune, and original stock tune. Is there a fix? Thanks.
2011 Jeep JK can't quick adjust or mod tune
Re: 2011 Jeep JK can't quick adjust or mod tune
please restore the stock tune then load this update then reload the tunes and let me know if the params are there.jdwarf wrote:Version: 1r13g
ValID: 68057155AF
- trinity_diablo_dcx_gas-1t13ha_update.crom
- (11.2 MiB) Downloaded 307 times
tech@diablosport.com
I was finely able to work on this. I installed the version you provided. The quick adjust menu was available as well as the modify tune parameters. The tune installed fine and everything seems to be working correctly now. Am I able to continue using the provided version or do I need to revert back to the 1r13g until the next update? Thanks
leave it on that version, all good
Thanks for the feedback.
