2000 Camaro Z28 Fan Adjustments?
I just picked up a 2000 Camaro Z28 LS1 Automatic last week, And started using my Trinity with it today. I couldn't seem to find any fan adjustments. Does the Trinity not have the ability to change when the fans turn on and off on a 2000 Camaro?
Re: 2000 Camaro Z28 Fan Adjustments?
they should be there, under the modify parameter menu.
tech@diablosport.com
I must be missing something. I go to Diablo tune, Modify tune, Modify parameter, And get these settings
Actual Wheel Size
Axle Ratio
COT
Downshift MPH
Idle RPM
Injector Slope
Part Throttle Shift Pressure
Power Enrichment
Rev Limit
Shift Time
Spark
Speed Limit
Torque Management
Upshift MPH
Upshift MPH Vs TP
Upshift RPM
WOT Pressure
Actual Wheel Size
Axle Ratio
COT
Downshift MPH
Idle RPM
Injector Slope
Power Enrichment
Rev Limit
Shift Time
Spark
Speed Limit
Torque Management
Upshift MPH
Upshift MPH Vs TP
Upshift RPM
WOT Pressure
appears to be missing for some reason.HiLuckyB wrote:I must be missing something. I go to Diablo tune, Modify tune, Modify parameter, And get these settings
Actual Wheel Size
Axle Ratio
COT
Downshift MPH
Idle RPM
Injector Slope
Power Enrichment
Rev Limit
Shift Time
Spark
Speed Limit
Torque Management
Upshift MPH
Upshift MPH Vs TP
Upshift RPM
WOT Pressure
Post up the backup and last tune written files from the tool and let me know how you want them set and I will do it for you in a custom tune for now.
