Board index inTune i-1000 Technical Discussion General inTune forum 2005 Chrysler PT Cruiser GT, Getting vehicle not suported
Bought a used I1000, tried to tune my 05 pt gt, keep getting vehicle not supported message, auto updater states there is no new updates available. Any help would be appreciated.
Ed
please post the info.xml file from the i2 drive here.
561-908-0040x4
hope this is what you needed,
<?xml version="1.0"?>
-<tool_info>
<main svn="9115" sw_rev="1r04j" full_version="InTune-1r04j 03/14/2016 10:51:37 AM"/>
<registration status="0" sn="J2EKGAE-4"/>
<cal_id CM1="05033329AC" PCM="05033410AH"/>
<restore bc="0" vin="3C8FY78G15T501467" id="0"/>
<system_db vin="1r01g" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01f" mfr="DCX"/>
<db pid="1r01b" tune="1r02h" mfr="FORD"/>
<db pid="1r01a" tune="1r02u" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="3C8FY78G15T501467" oem="DCX" calid="05033410AH"/>
<updates count="0"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
please attach the actual file.
561-908-0040x4
Here you go, thanks
Ed
info.xml
(1.9 KiB) Downloaded 43 times
mustangii wrote:
Here you go, thanks
Ed
save this to the intune drive and let the device import the file then you can load it to the car then install the tune.
3C8FY78G15T501467_05033410ag.drg
(382.71 KiB) Downloaded 43 times
561-908-0040x4
Thank you sir.
Ed
Return to General inTune forum
