Board index inTune i-1000 Technical Discussion General inTune forum Intune freezing
Intune freezing
Post Fri Jun 03, 2016 11:27 am
hello,
I have forwarded your flip file to your email.
Daniel Gomberg
Tech Support
Phone: (561)-908-0040
Fax: (561) 431-0429
Post Fri Jun 03, 2016 3:34 pm
Didn't last long. Tried to make a few changes to the Torque Management settings, loaded tune and it then said that it had a failure and would need to create a failure log. Now I can no longer load anything.
Registry is;
0016A4
47092D
843DA0
9E7C0D
CBFAA5
dang wrote:
hello,
Post Fri Jun 03, 2016 3:59 pm
Here are the new files:
TCM_24250667_Backup.grg
(15.54 KiB) Downloaded 535 times
ECM_12631165_Backup.grg
(57.52 KiB) Downloaded 533 times
info.xml
(2.24 KiB) Downloaded 545 times
Post Sun Aug 14, 2016 7:45 am
Can someone help. 2015 Chevy Cruze 1.4l LTZ Whenever I try to tune it now it freezes and won't do anything. Please help. it always freezes once the intune says to turn the key and the tuner starts to load, but always ends up just hanging forever.
Post Mon Sep 12, 2016 1:29 pm
Hi
Whenever i try to install a tune, my device gets stuck at 94% (for over an hour) trying to backup the stock tune. Please help!
Post Wed Sep 14, 2016 1:05 pm
sarim1010@gmail.com wrote:
Hi
please update the tool on a PC and try it again.
561-908-0040x4
Post Sat Feb 04, 2017 4:36 pm
So my Intune is doing the same how can i fix that?
I can load it up but as soon as the lil dile goes in circles it freezes ,help please!
Post Thu Apr 13, 2017 2:22 pm
My intune keep freezing when I want to tune my vehicle. What could I do?
Post Thu Apr 13, 2017 6:15 pm
me too please we need help its freezing in stage 1 when its reading the car backup ?
Post Mon Sep 18, 2017 5:10 pm
same thing here with freezing... registry reset pass?
657197
C6F6D5
8B57AA
78EC15
02AFED
Post Tue Dec 12, 2017 9:00 am
Anyone heard any more on fixing this issue? Having the same problems with it freezing. I did notice that although it froze at the end of the process of writing the 87 Octane tune, DOD or AFM on my 07 Chevy Silverado is now turned off which is an option I had set to be turned off. Don't know if the rest of the tune was successful though.
Post Fri Jan 05, 2018 8:50 pm
im using a in tune 1000 on my 08 Tahoe ltz 5.3 and it installed tune but when i try to go back to stock its says no pcm or it freezes up any help would be great
Post Tue Jan 09, 2018 1:08 pm
please give us a call with the tool powered up in the vehicle and we'll get you going.
561-908-0040x4
Post Wed May 23, 2018 1:45 pm
Well, add me to the list of freezing, for my intune DCX. My device freezes, just after I try to write a custom or any of the canned tunes. The recovery works fine and restores the original backup. 2013 Dodge Challenger 5.7L
The key is:
138CC0
3BCC9B
B6811F
8F026F
1E3EA9
Edit:
Never mind, the update worked. Re-tuned!
Post Wed Jun 20, 2018 12:25 pm
I'm having this same problem? Should I update and try again first or should I just call in? Number to call?
Lucas
PreviousNext
Return to General inTune forum
