Board index inTune i-1000 Technical Discussion General inTune forum data logging problems
Post Sat Apr 28, 2018 6:52 am
hi, need help with data logging!! everytime I try a log, I get no live PIDs on the tool, only 3 anologue resuts come up on the reader. the only thing showing on the tools screen is a small dot in the centre! have reset to default PIDs countless times, have run ignition updater several times and the tool is up to date, have tried installing seperate PIDs and selecting all still no joy... has anybody had the same problem?
Post Wed May 02, 2018 1:09 pm
please post the info.xml file from the intune drive.
561-908-0040x4
Post Wed May 02, 2018 1:30 pm
thanks for the response
info.xml
(1.89 KiB) Downloaded 132 times
Post Fri May 04, 2018 7:44 am
the device is up to date, not sure if this is a device or vehicle issue at this point.
I see you are tuning an 05 Chrysler, what is it specifically?
561-908-0040x4
Post Fri May 04, 2018 7:49 am
hi Mikel,
info file sent as requested, no reply!
Post Fri May 04, 2018 7:54 am
my mistake, didnt see your reply! 2005 dodge magnum sxt v6, had no problem in the past with logging, seems only to have happened since updating with ignition, took a log before that for the original custom tune, now I cant log to have it tweaked, any way to wind back the update?
Post Fri May 04, 2018 7:57 am
when did you update it?
561-908-0040x4
Post Fri May 04, 2018 8:11 am
less than a week ago
Post Mon May 07, 2018 7:14 am
Return to General inTune forum
