DataViewer Driver for Intune
Live streaming of the InTune, using DataViewer, requires the use of the following driver.
- Diablosport_USB_Driver_Installer_2.0.exe
- (1012.62 KiB) Downloaded 1927 times
Re: DataViewer Driver for Intune
I cannot use data viewer..i have windows 8 and it states that its unable to open because side by side configuration is incorrect????? I downloaded the driver and it still wont work, says the same thing.
tech@diablosport.com
I'm running into the same issue with the "side by side configuration is incorrect" on a windows 8.1 pc. I've tried installing the application to a different location other than the program files x86 folder, but I get the same error.
I also tried the suggestion above, but that didn't seem to help anything either.
