they're closed for Christmas holiday.. won't be back until Tuesday...
Technical Support
Telephone: 561-908-0040
PCM Calibration update needed error
Re: PCM Calibration update needed error
Am having the same problem on my Jeep the dealer probably did an update too what do I do?
Bought a i1000 used got it unlocked and now i am getting the pcm calibration update needed error. what do i need to do????
- info.xml
- (1.76 KiB) Downloaded 544 times
what is the year, model, engine of your vehicle????
Hello,
I have an I-1000 DCX. My tuner worked 2 days ago then I took it into the dealership for a new thermostat. Now, I get the message:
PCM calibration for 2C3CDXHG0DH571568 might need an update. Check for a calibration update?
Update manager says my tuner is up to date...but I just get the same msg again and again.
Help!
Help!
posty the info.xml file from the intune drive please.
tech@diablosport.com
info.xml file attached.
Thanks!
ccbenn
Thanks!
ccbenn
- info.xml
- (2.33 KiB) Downloaded 472 times
you didn't return it to stock prior to the dealer update, so the device needs to be reset.
give us a call with it powered up and reference that I asked you to call for a reset.
Thanks Mike!
I'll call Wednesday morning.
Thanks again,
ccbenn
Thanks again,
ccbenn
Hi Mike,
My fuel pump failed and was towed to the dealer where they flashed the PCM. I am now having this same issue where it keeps telling me to do a calibration update but no update is found when I plug into the update agent. Attached is my info.xml. Can you help me get this solved?
- info.xml
- (1.8 KiB) Downloaded 285 times
if you didn't restore prior to going to the dealer you'll need to call in and have the device reset first.
