PCM Calibration
Re: PCM Calibration
Yes, the dcx tool you have is for 11-14
tech@diablosport.com
nightrunner06
Re: PCM Calibration
Post by nightrunner06 »
im having this same problem, calls for an update and it doesnt update. pc or Mac. pc cannot run intune app.
returned to stock to get dealer updates, come home to this.
2014 ram
Re: PCM Calibration
what happens when you try to run the updater app on the PC?
Re: PCM Calibration
nightrunner06 wrote:im having this same problem, calls for an update and it doesnt update. pc or Mac. pc cannot run intune app.
2014 ram
copy this to the intune drive and let the tool import it then try tuning again, if it still asks for an update at vehicle run the updater pr post the new info file here please.
nightrunner06
Re: PCM Calibration
it tried to update, but now it says its not registered?
i dont think I accidentally did it when trying to get it to work before?
EDIT: I JUST DID REGISTER IT (again?)
Re: PCM Calibration
nightrunner06 wrote:it tried to update, but now it says its not registered?
save this ot the intune drive to register the tool then load the update.
nightrunner06
Re: PCM Calibration
thanks, it seems to have updated properly , except it claims to still want an update when plugged into the truck.
I have the ran update you sent me two separate times.
not sure what i'm missing.
djpiezo
Re: PCM Calibration
Post by djpiezo »
nightrunner06 wrote:thanks, it seems to have updated properly , except it claims to still want an update when plugged into the truck.
I'm experiencing the same problems as well.
I have the diablo tune(93 Octane) installed but I want to try the 91 octane tune but it prompts me
that I need a calibration update Before I Can Install it
It might Be A Software Issue
nightrunner06
Re: PCM Calibration
would be nice to get this resolved as my intune is an expensive paper weight at the moment.
Re: PCM Calibration
nightrunner06 wrote:would be nice to get this resolved as my intune is an expensive paper weight at the moment.
please post the current info.xml file from the intune drive.
nightrunner06
Re: PCM Calibration
current info
Re: PCM Calibration
nightrunner06 wrote:current info
file is downloading properly, run the updater and let it download the fiel or I attached it here, save to intune drive and let tool import it then go to vehicle and load update then tune.
nightrunner06
Re: PCM Calibration
Thank you! that finally did it.
Must have issues updating by itself. I have to drag and drop everything
schamb86
Re: PCM Calibration
Post by schamb86 »
I'm having same issue too. 2011 Jeep GC 5.7L
I have not been to dealer.
Attached the info document you're referencing
Re: PCM Calibration
schamb86 wrote:I'm having same issue too. 2011 Jeep GC 5.7L
just needed to update the tool again, save this to the intune drive and let the device import it then go load it to the vehicle then you can load the tunes.
