Board index inTune i-1000 Technical Discussion inTune DCX (i-1000-DCX) Another Vehicle Not Supported
Post Sat Apr 15, 2017 12:37 pm
Took my 2012 R/T in for recall work. I restored the factory tune prior to taking it in While in the shop, the dealer applied 2 flashes. Now I get the vehicle not supported message. Updated the tuner on line and tried again. Now it's asking to check for a calibration update. Wanted to check here before I proceed further. Advice? Things to do and not to do?
Jack
Post Mon Apr 17, 2017 6:56 am
My dealer hleps me to fix it. The problem is the version of the recall tune. your dealer could flash the pcm tune with the same version of your diablo. Then the diablo goes back to work nomally. :evil_angel:
Post Tue Apr 18, 2017 2:24 pm
I grabbed the calibration file and it looks like the tuner now wants to upload it to the PCM. I haven't backed up my PCM yet and was concerned as to what this calibration update does to the PCM.
Post Tue Apr 18, 2017 7:29 pm
I'm having the same issue with my 2012 Challenger after my recall on the timing chain. I believe they did a flash update as well. I had one of the techs send me a file to install on my tuner but it did nothing. I am hoping we get resolution on this as I have been working on this same issue for a couple weeks, many calls to support desk, hours on hold - still not working.
Post Wed Apr 19, 2017 12:27 pm
anyone in this spot, please post your info.xml file from the intune drive and we'll sort it out.
561-908-0040x4
Post Wed Apr 19, 2017 1:38 pm
Will do as soon as I get home.
Thanks!
Post Wed Apr 19, 2017 4:49 pm
Attached is my info.xml
Post Wed Apr 19, 2017 7:45 pm
My file
Post Wed Apr 19, 2017 8:54 pm
my file
Post Thu May 04, 2017 11:45 am
Any updates?
Post Mon May 22, 2017 12:58 pm
G30Jack wrote:
My file
save this to the intune drive then let it update than it should work.
561-908-0040x4
Post Mon May 22, 2017 12:59 pm
frog19871230 wrote:
my file
this device is already married, did you go to the dealer while the tune was loaded?
561-908-0040x4
Return to inTune DCX (i-1000-DCX)
