2013 Chrysler 300C 5.7L AWD
I have the 93 octane (Diablo) tune loaded on my car and use 93 octane gas. After doing a lot of reading and on-line research of other forums, I decided to try mixing some E85 (105 octane) in on my last fill up. My tank is 19 gallons and I put 2.7 gallons of e85 on top of 93 octane gas. I also added 2% fuel enrichment to WOT in all RPM ranges. WOW! I noticed an immediate difference in WOT pull and in throttle response. At this mix rate, there is approximately 11% e85. So far, there has been NO drivability/runability issues. While I recognize the issues of using - 100% - e85, ie, AFR, Stoichiometric calculation, injector size and fuel pump capacity; I'm not interested in 100% e85, just interested in mixing/adding a few gallons of e85 as an octane booster.
My questions for you are, considering my vehicle:
1. Does the 93 octane (Diablo) tune change the parameters that my stock ECM can adjust for AFR?
2. I recognize that Diablo cannot recommend this mixing practice and I am not looking for a recommendation, however, in your professional tuner experience, do you think that up to a 30% e85 mix would be an issue for the ECM to adjust for?
3. Not looking for a recommendation; do you think adding to WOT timing above the 93 octane tune will be of benefit?
Mixing E85 with Regular Gas
Jump to
- Welcome to DiabloSport
- ↳ Announcements
- ↳ Test Vehicles Wanted
- i2/i3 Technical discussion
- ↳ i2/i3 for Dodge, Chrysler, Jeep and Ram
- ↳ i2/i3 for Ford vehicles
- ↳ i2/i3 for GM vehicles
- ↳ Ignition updater
- Trinity 2
- ↳ T2 for Dodge/Chrysler/Jeep/Ram
- ↳ T2 for Ford
- ↳ T2 for GM
- ↳ Trinity MX monitor
- Predator 2 Support
- ↳ Predator 2 for Chrysler/Dodge/Jeep/Ram
- ↳ Predator 2 for GM
- ↳ Predator 2 for Ford
- Pulsar
- Trinity Technical Discussion
- ↳ General Trinity
- ↳ Trinity Ford Gas
- ↳ Trinity Ford Diesel
- ↳ Trinity Dodge Gas
- ↳ Trinity Dodge Diesel
- ↳ Trinity GM Gas
- ↳ Trinity GM Diesel
- inTune i-1000 Technical Discussion
- ↳ General inTune forum
- ↳ Auto Updater/PC related issues
- ↳ Mac/Non Windows based issues
- ↳ inTune DCX (i-1000-DCX)
- (Legacy) Predator Technical Discussion
- ↳ Predator Ford Gas
- ↳ Predator Ford Diesel
- ↳ Predator Dodge Gas
- ↳ Predator Dodge Diesel
- ↳ Predator GM Gas
- ↳ Predator GM Diesel
- General Technical Support
- ↳ PowerPuck/Extreme PowerPuck
- ↳ DeltaChip
- ↳ MAF.i.a
- ↳ CMR Support
- ↳ DS Downloader
- ↳ DataViewer
- ↳ General Support
- ↳ CatchCan Support
- DiabloSport Community
- ↳ General Questions
- ↳ Lounge
- ↳ Suggestion Box
- ↳ Future Product Requests
