Board index inTune i-1000 Technical Discussion inTune DCX (i-1000-DCX) I-1000 PCM calibration error.
Post Mon Jun 26, 2017 8:44 am
I am having problems tuning my 2013 Ram 1500, my I-1000-DCX does not have the intune.exe to run and when I connect it to my truck it says "PCM calibration (VIN) etc." I have not seen a solution for adding the update installer exe, or a manual PCM update. Is there a way to do this? I'll add my info.xml when I get home this afternoon if that helps.
Last night I drag and dropped all files (with the exception of the GM and Ford files) over to my intune drive at it seemed to work.
**edited subject to more accurately describe problem**
Post Mon Jun 26, 2017 9:43 am
install the ignition software from our downloads page to update the device.
561-908-0040x4
Post Mon Jun 26, 2017 3:07 pm
I have installed the Ignition Install software, and it updated 2 files, however I am still getting the PCM calibration error. Attached is my info.xml, please let me know if there is anything else I can do to remedy this.
Post Mon Jun 26, 2017 3:20 pm
the device is already married to the truck, did you have the vehicle at the dealer since you last installed a tune?
561-908-0040x4
Post Mon Jun 26, 2017 3:25 pm
Nope, never had the truck into the dealer. I did plug the unit into the truck before the updates to change tire size...crap did I just brick this thing?
Post Tue Jun 27, 2017 6:20 pm
Can anyone tell me whether there is a way to fix this situation, or am I just hosed?
Post Wed Jun 28, 2017 7:53 am
try restoring the tire size, as that is what married the device. It will not pull the requested update while the device is married.
561-908-0040x4
Post Wed Jun 28, 2017 8:54 am
I'll give it a try, hopefully it'll work. But I thought the tire changes were under the edit/modify tune options, which I can't get to because of the damned PCM calibration error.
Thank you for all your help Mike, I really do appreciate it!
Post Thu Jun 29, 2017 3:24 pm
Mike,
As I thought since tire changes is within the tune menu I cannot change them now (which is a pain because they do need some tweaking, and we're in the middle of a road trip). Should I just call to try and work this out? I just bought the unit brand new less than a week ago, and couldn't wait to get my truck tuned.
Post Fri Oct 13, 2017 1:20 pm
im also having issues with my pcm calibration for a 2006 dodge magnum sxt.
Return to inTune DCX (i-1000-DCX)
