Frustrated as heck
noduckingway
Frustrated as heck
Post by noduckingway »
I called support and verified my Vehicle (2015 Chevy Colorado 3.6) would work with the i-1000. After several rounds of update failures and emails, I still can't tune the truck. The device is finally up to date according to the ignition software. PCM shows up as unknown, email support. I am apparently catching a different person as shifts change. Is it always this difficult? I really just wanted to adjust the tire size..... maybe get the transmission to not suck so bad. Restored the original tune, so not sure if the xml will help but attaching.
Re: Frustrated as heck
You posted here in the inTune DCX forum, so if this is indeed an inTune i-1000-DCX tool, then no, it will not work on your GM vehicle.. the DCX tool is only for dodge/chrysler vehicles...
noduckingway
Which adds to the frustration since there isn't another forum with i-1000....
noduckingway wrote:Which adds to the frustration since there isn't another forum with i-1000....
General (non DCX) forum here:
https://forum.diablosport.com/viewforum.php?f=44
Its possible you have a new cal in the truck that wasnt added to the i1000, please try loading the attached file, it is the latest database for the i1, if this does not support it then unfortunately we have no way to add it to this older device.
tech@diablosport.com
