Board index inTune i-1000 Technical Discussion inTune DCX (i-1000-DCX) PCM Calibration (vin#)
Post Sun Aug 13, 2017 1:59 pm
I bought a used intune i1000 i plug into my truck and it says a I need a PCM CALIBRATION and then my vin number and it tells me I can now disconnect and hook up to PC. Once I do so I plug in intune it starts an app i2 updated it updates the tuner plug it back into the truck and the truck says the same thing. I try to for calibration but it gives me 5 different set of key codes which don't work. I've read on another post to erase all updates and re do it which I did still the same problem. On another threat it said to email diablo sport info.exe file or something which I did hopefully I hear back from them Monday. If anyone has had a similar problem and found the fix please share with me! Lol thank you in advance
Post Mon Aug 14, 2017 10:03 am
561-908-0040x4
Post Mon Aug 14, 2017 11:42 am
Here's the stuff inside the info.xml
<tool_info>
<main full_version='InTune-1r04j 03/14/2016 10:51:37 AM' sw_rev='1r04j' svn='9115'/>
<registration sn='JNLBQF6-6' status='1'/>
<cal_id PCM='68064937AH'/>
<restore id='0' vin='3C6JD6CT6CG261349' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01g'/>
<db mfr='DCX' tune='1r01f' pid='1r01b'/>
<db mfr='FORD' tune='1r02h' pid='1r01b'/>
<db mfr='GM' tune='1r02u' pid='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='68064937AH' vin='3C6JD6CT6CG261349' oem='DCX'/>
<updates count='16'/>
<oem tool_oem='DIABLO'/>
<reg reg='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'/>
</tool_info>
Post Mon Aug 14, 2017 11:54 am
I need the actual file posted here please.
561-908-0040x4
Post Mon Aug 14, 2017 12:05 pm
info.xml
Post Mon Aug 14, 2017 12:06 pm
Sorry I'm using my phone and the file is in my email I will try to access a computer to properly attach the file
Post Mon Aug 14, 2017 1:19 pm
Here it is Mike.
Post Tue Aug 15, 2017 9:20 am
when it says it needs an update, you need ot click the green check mark to trigger the request, then run the ignition software or post a fresh copy of the info file here.
561-908-0040x4
Post Tue Aug 15, 2017 11:35 am
I do click the check mark I even take my laptop out to my truck and instantly plug it in to my PC and open ignition it then tells me I have all the updates. I have attached the most recent info.xml :crashing:
Post Tue Aug 15, 2017 12:15 pm
save this to the intune drive and let the device import it then go to the vehicle and load the update then you may tune it.
561-908-0040x4
Post Tue Aug 15, 2017 12:37 pm
I uploaded the file I still keep getting the same PCM calibration message check for updates and it says to plug into my PC again
Post Tue Aug 15, 2017 1:13 pm
well, I see the issue, you are trying to use an i-1000 here, and you need an i1000-dcx model, or newer i2010.
561-908-0040x4
Post Tue Aug 15, 2017 1:51 pm
That sucks is there any way to get it swapped out?
Post Tue Aug 15, 2017 2:12 pm
contact support@diablosport.com about the Trade-in Program.. you can trade in your old intune i1000 and they will give you a $100 discount on buying a new inTune i2 i2010 from them.
Return to inTune DCX (i-1000-DCX)
