hi,
after update the oem program, the rev can not be setted up cuccessfully.
I wanna set my vehicle rev limit to 7000r/min in gear "D/S", but it failed. I have tested my car in gear "S" , the rev was limited at 6200+ r/min. and I also tried it in manual gear , it be limited at 6850r/min.
I will upload my info and last tune later.
chrysler 300 2013 rev set in D/S set failed
Re: chrysler 300 2013 rev set in D/S set failed
6850 is likely the TCM limiter, If you set it to 7K and managed to get 6850 in manual mode than thats all its got to give with tcm programming
tech@diablosport.com
hahaha, i see, thx mikelmikel wrote:6850 is likely the TCM limiter, If you set it to 7K and managed to get 6850 in manual mode than thats all its got to give with tcm programming
