1RO3X cannot be replaced
I'm getting this code when trying to update my DCX. Any ideas?
Re: 1RO3X cannot be replaced
delete that group_update file from the tool... then disconnect the tool from your computer.... . reconnect it.. and run the updater again...
Where on the tool is it found? I can’t find it on any of the menus on the tool or any folders on the computer.06MonteSS wrote:delete that group_update file from the tool... then disconnect the tool from your computer.... . reconnect it.. and run the updater again...
load the attached file to the intune drive and let it import it then run igniton again after deleting the file Lew mentioned.
tech@diablosport.com
