Board index i2/i3 Technical discussion i2/i3 for Dodge, Chrysler, Jeep and Ram Calibration problems
Post Mon Dec 02, 2019 9:11 pm
I purchased a used i2. it is unmarried. i downloaded all updates but when i plug in it says got to pc to update calibration. I've done this several times but it still asks for calibration update. Help!
Post Tue Dec 03, 2019 9:11 am
please post the info.xml file from the device and provide specifics about the vehicle.
561-908-0040x4
Post Tue Dec 03, 2019 9:13 am
Thanks will do when I get home.
Post Tue Dec 03, 2019 8:59 pm
my car is a 2005 Chrysler 300c 5.7 awd. here is the info file you requested
Post Wed Dec 04, 2019 9:21 am
copy this file to the root of the intune drive and let the device import it then load it to the pcm then you can tune the vehicle.
561-908-0040x4
Post Wed Dec 04, 2019 11:14 am
Thank you. So plug the tuner into computer and drag it over to where my original file was? And it will over write the original file. I’m guessing.
Post Wed Dec 04, 2019 12:35 pm
not overwriting anything.
Just cop[y the file to the root of the drive and let the device import it.
561-908-0040x4
Post Wed Dec 04, 2019 9:46 pm
I put the file on the intune. That worked, now I get no Ecu found check ignition. I keep trying then it says check cable. But it will read if there is codes in the car. What do I do now?
Post Wed Dec 04, 2019 11:22 pm
Please disregard got it working.
Return to i2/i3 for Dodge, Chrysler, Jeep and Ram
