'17 PCM install
'17 PCM install
I received my programmed PCM from Diablo. The PCM instructions were for a push button start. However my truck fired right up and throttle appeared to work fine. I went ahead and did the throttle press , try and start for 5 sec, turn off and start procedure just in case. Is there anything else that I need to do it appears I am good to go I just wanted to make sure.
Re: '17 PCM install
all set
tech@diablosport.com
