Went to make a couple changes to the Tune this morning and as it was writing crashed and went into recovery mode. it re-flashed the backup it took and then gave me the Vehicle not supported.
I have updated the unit and there are not updates
Also Now Getting No Valid Calibration update Available Contact Support....... HELP!!!!!!!!
I have attached my XML
Also while i got you i would like to see about getting a custom tune done thru the email.
Vehicle Not Supported i2
Re: Vehicle Not Supported i2
the device is not requesting an update.
Please try again at the vehicle.
tech@diablosport.com
I have tried it again without any luck
post the new info file after trying again please.
Here you go
save this to the i2 drive, let the tool import it then load the update to the vehicle then you can install the tuneschbrjadeka wrote:Here you go
Works! Perfect.
