I2 With PCM exchange issues
Ok I've got a 2015 Turbo'd 5.7l Ram. I recently have started having a issue with the OBDII port not having power. I checked the fuses and sure enough the "F93 position" 20amp in the fuse panel is blown. I replaced it and it blew almost instantly. Replaced the Relay and Fuse again and the OBDII port will power up for a little over 1 minute. Then the fuse blows again. I have traced wires and found that there is nothing on either side of the circuit grounded "Shorting out" so my question is could it possibly be in the PCM itself? The I2 works perfect when hooked up though the laptop luckily The current tune on the truck is the 93 octane tune and not the race tune. I would like to speak to someone on the phone or Email about this issue. Everything is pointing towards the PCM but I would like to pick someones brain on the issue that has more knowledge than I do with this product.
2015 5.7 Ram
78mm Turbo Build
78mm Turbo Build
Re: I2 With PCM exchange issues
Have you tried installing the stock pcm to see if the issue persists?
tech@diablosport.com
Looks like we have it all sorted out. Something in the Tuner was acting up causing a blown fuse in the truck. I should receive it back from you guys today hopefully weather permitting. Tha yall for the support and help along the way!mikel wrote:Have you tried installing the stock pcm to see if the issue persists?
2015 5.7 Ram
78mm Turbo Build
78mm Turbo Build
Glad to hear it.
