how do you disable the mds with the intune i3. also when i tried changing shift or rev it would say read back error.
this is my first time using one of these.
2007 300c
Re: 2007 300c
select the tune then choose the modify parameter option and go to MDS, set it to OFF, then back up and apply the tune.
tech@diablosport.com
Re: 2007 300c
still cant do any parameter modifying. just tire size, gear ratio, shift stiffness.
Re: 2007 300c
you dont have the modify parameter menu in the advanced tune menu?
