I2 ECU not supported?
The car is a 2013 dodge charger.. I connect the i2 to the ignition program let's it do it's update thing..unplug it, take it to the car hook it up, hit the tune set up and i get this ecu not supported in this vehicle...am I missing something, most of the options on the i2 are greyed out aswell..
Re: I2 ECU not supported?
please post the info.xml file from the i3 drive.
tech@diablosport.com
hers the file
save this to the root of the i2 drive and let it import the file then load the update to the car then you may tune it.jrod323 wrote:hers the file
everything is working properly now, thanks mikel
