Recieving popup ECU's Not Supported.
Hi, I am receiving a popup telling me some ECU's are not supported and to update whenever I try to tune my 2014 Dodge Charger 3.6l. I was able to successfully install the "Stock Tune", but am not able to adjust any parameters. I also do not have options for a 91 or 93 octane tune. Using Intune I3- 8345. Here is the XML file too.
Re: Recieving popup ECU's Not Supported.
i am having the same issue on my 2015 jeep grand cherokee summit 5.7
i have updated the tuner 3 times
please give us a call so we can reset the device and then you should be able to load the needed cal updates and proceed.bgomes wrote:Hi, I am receiving a popup telling me some ECU's are not supported and to update whenever I try to tune my 2014 Dodge Charger 3.6l. I was able to successfully install the "Stock Tune", but am not able to adjust any parameters. I also do not have options for a 91 or 93 octane tune. Using Intune I3- 8345. Here is the XML file too.
tech@diablosport.com
if it is telling you to check for updates each time, please give us a call so we can reset the tuner.sultech2 wrote:i am having the same issue on my 2015 jeep grand cherokee summit 5.7
