Hi there,
now i have an i3 für my RAM 1500 MY 2014 5,7L HEMI 8-Speed. ATM i have the 91Octane-Tune installed at my RAM. Also deactivated the VMax-Limit.
But is that an issue or a feature ? At some point above 170km/h (original VMax-Limit) the Cruise Control will be deactivated. It can be activated, but when pushing SET it becomes deactivated again, unless i restart the engine. The actual speed doesnt matter. First Reboot of the Car will bring this functionality back.
- Is it possible to set the limits for the cruise control manually ? Would need a 30km/h possibility, normally it starts at 40km/h.
- DSC deactivating. How long will it be deactivated ? Must the i3 keep in place to enable/disable this feature, or can it be done with the norma ABS/DSC OFF Switch ?
- My RAM ist also running on LPG (Liquid Petroleum Gas), are there special settings for this fuel ?
Sorry for maybe bad english, i am from Germany.
Greetings, Henere
New i3 with RAM 1500 MY2014
Re: New i3 with RAM 1500 MY2014
Not sure about the cruise control, its likely related to the torque management.
Disabling ABS lasts for one run cycle, it should re-enable next time you start the truck.
I dont have any advise for running LPG...
tech@diablosport.com
