180 t-stat
180 t-stat
Switched to a 180 t-stat, now I keep getting a check engine light regarding coolant temp, how can adjust this on the i2, I don't see a function for this
Re: 180 t-stat
post the last tune written file and I will adjust it for you.
tech@diablosport.com
Re: 180 t-stat
these are the 2 that show up, not sure which 1 it would be, also how can I adjust my fans to turn on at lower temp?
Re: 180 t-stat
this will keep you from getting the code.
You should have a fan control option in the modify param menu to lower the target coolant temp.
Re: 180 t-stat
Cool thanks i.ll give this a try, much appreciated
