I just received a recall update to my 2017 Durango 5.7L for Cruise Control U65 & AutoPark U05.
I removed all the tunes before taking my DD in for service. Once I got her back I was trying to reinstall the tunes. The I3 asked to recalibrate the TCM and PCM which seemed to complete and before the last OFF / ON cycle I got a failed update. The Diablo PCM is now bricked and the I3 unit is in recovery mode. I have pulled the PCM and replaced it with the stock unit until I can get a response from Tech Support (sent on 9/18) or a response on this forum.
I've attached the info.xml file from the I3 tuner to review.
Bricked PCM after Recall
- D3-Blk-Hemi
'22 Durango Blackout R/T+
Re: Bricked PCM after Recall
Not sure what happened here.
Can you give us a call with the mod pcm installed so we can try resetting the device and forcing it to load an update?
tech@diablosport.com
Not sure if this is somewhere in the forums, but if I want to get my car checked for that recall they have been bugging me about, how do I get that checked? I have the I3 which I can just go back to stock, BUT I also had my PCM unlocked, will they cover, is it Okay not to have it checked, will there be another charge if they lock it again, etc...?
they dont lock it again, just be sure to return to stock and let them do their thing, but the device will put you back on the current cal if you want to tune it again after, so...its up to you.
