Vehicle not supported and Unsupported file
I just received my i2 and updated it. I went to connect it to my 2013 charger 3.6 and got vehicle not supported. I connected it to ignition was told i needed an update and it says Unsupported file for your calibration not found someone please help
Re: Vehicle not supported and Unsupported file
copy the attached file to the root of the i3 drive and let it import the file then load it to the car then you can tune it.
tech@diablosport.com
This is also a 2013 Charger 3.6/8speed, same exact problem, but I3. Can you please help?
"This Vehicle is currently Not Supported: an update may be required. Please plug this device into a PC to download any updates."
pluged in to PC
"Unsupported file for your calibration not found. Please contact technical support."
as info.xml shows:
2C3CDXHG4DH510336
Cal ID: 68171342AC
TCM: 68046526AL
As above I see people write with this same issue and you send them a file to enable tuning. Should I write to technical support? This guy left his car...
pluged in to PC
as info.xml shows:
2C3CDXHG4DH510336
Cal ID: 68171342AC
TCM: 68046526AL
copy this to the root of the drive and let the device import it then load it to the pcm.
Thank you SO MUCH, Mike!
Really appreciated!
Looks like Dodge's PCM calibration update removes Fuel Shut Off from Torque Management.
Thanks again,
Jeff
Really appreciated!
Thanks again,
Jeff
