2014 dodge durango RT not showing tcm
Im having an issue with my Intune i2050. It was previously on 06 srt8. I returned it back to stock and put the intune on the durango. After i hooked it up to my pc and did all the latest updates from ignition. It only shows pcm. Doesnt not show tcm like when I had it on my charger. I have no problems successfully completing the tune but I can tell im not getting the performance out of it. I chagned my shift points over 6300 and when i floor it, it still shifts at 56-5700rpms. Put throttle boost up 20% but i cant tell the difference. I appreciate if someone can help. Thanks
Re: 2014 dodge durango RT not showing tcm
6 or 8 speed?
8 speed support is specific to 15+ models.
tech@diablosport.com
It's a 8speed. So does the tuner work at all? Like for the fans and throttle boost?
8 speed is specific to 15+, you will have fans, and everything else you'd expect for the pcm.
Well least some stuff works. Appreciate you answering my questions. Thanks
