[HELP] 2016 Mustang test tune
StangATX
Post by StangATX »
Hey guys,
I'm having some trouble with my car right now. I'm back to stock tune for about 1 1/2 month and I still loose my fuel economy. I tried to clean my TB and I'm still loosing quit a bit of gas. I checked for leak and the only one I have is the OEM Ford clamps between my cat and my resonator (I Just ordered new clamps right now to fix those exhaust leaks). I was gonna look to remove my O2 sensor to check them out and clean them but I don't have the special socket and on my car it's a little pain in the butt to remove the 4 O2 sensors. Anyways, here's a little request for you guys. I'd like to see if you could disable the 2 sensors that are on my cats but keep the one before my cats. I don't have any CEL so I just wanna see if with those 2 sensors disable if my car will gain it's fuel economy back. If it does I'll just bring it back to stock and change my O2 sensors. Also, I tried to reflash my car yesterday and it was stuck on reading PCM 25% for like 5 mins. I couldn't get my car to be flashed with the 87 tune.
PS: Forgot to mention my Mustang is a V6 AT.
Thanks for your help!
StangATX.
Re: [HELP] 2016 Mustang test tune
rear o2 sensors should have no effect on fuel economy....
tech@diablosport.com
StangATX
Post by StangATX »
I probably got confused then. For some reason my car runs really rich :(
StangATX
Post by StangATX »
Any idea why the tuner stop reading the PCM at 25%???
StangATX
Post by StangATX »
Quick update... the tuner couldn't pass 25% of reading the PCM. I thought it needed an update. I connected the tuner over WiFi and it found a few updates. After updating the tuner and plugged it in my car something really weird happened. It said my car wasn't supported! So, before the update my car was supported but now it isn't anymore? what just happened!!!?
StangATX wrote:Quick update... the tuner couldn't pass 25% of reading the PCM. I thought it needed an update. I connected the tuner over WiFi and it found a few updates. After updating the tuner and plugged it in my car something really weird happened. It said my car wasn't supported! So, before the update my car was supported but now it isn't anymore? what just happened!!!?
please post the current info.xml file from the i2/i3 drive.
StangATX
Post by StangATX »
Anyways of getting it without computer? For some reason it's not detected on 3 different computer with 2 different USB cable...
whats the device serial number?
StangATX
Post by StangATX »
mikel wrote:whats the device serial number?
According to an older backup of my xml file it should the following: 1FSY7KDKTJ
Edit: I just found another Micro USB cable and I thought why not try. After 2 cable being bad if this cable doesn't work then something is probably wrong... Anyways, The cable I found seems to work (For now...) on Windows and I got my "Info.xml" file. My computer can now detect the tuner! However, I'm still having trouble with my car. Since the last update I did over WiFi it says my car is not supported... I did the update because the tuner was stuck at 25% reading PCM and wouldn't move further. Anyways, Here's the file:
Code: Select all
<tool_info platform='I2'>
	<registration sn='1FSY7KDKTJ' status='0' tool_oem='DIABLO_F' updates='0'/>
	<applications count='5'>
		<application name='vehicle' rev='2r01z'/>
		<application name='updater' rev='2r01e'/>
		<application name='gui' rev='2r01o'/>
		<application name='installer' rev='2r01i'/>
		<application name='logger' rev='2r01a'/>
	</applications>
	<databases dbnames='2r00' dtc='2r01a' vin='2r01h' gui='2t01ha'>
		<database mfr='DCX' pid='2t01et'/>
		<database mfr='FORD' tune='2r02m' pid='2t01dk'/>
		<database mfr='GM' pid='2t01cr'/>
	</databases>
	<system rev='1r01a' config='1r01d'>
		<option name='Wifi' enabled='true' driver='v4.0.2_9000.20130911'/>
	</system>
	<last-connected vin='1FA6P8AM9G(THE REST OF MY VIN)' mfr='FORD' ecus='1'>
		<ecu calid='FNGS1F3' spn='GR3A-14C204-EBA'/>
	</last-connected>
	<licenses available='1' tuned='0'/>
	<unsupported calid='FNGS1F3' vin='1FA6P8AM9G(THE REST OF MY VIN)' oem='FORD' spn='GR3A-14C204-EBA'/>
	<reg reg='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'/>
</tool_info>
everything looks current there. Not sure what could cause this.
Can you give us a call this morning with the tool powered up in the car so we can try resetting it and see if that clears it up?
StangATX
Post by StangATX »
I will call on tomorrow (Friday 9th). Thanks!
