Board index i2/i3 Technical discussion i2/i3 for Ford vehicles vehicle not supported?? i3 update not loading 2 files??
I have a i3 here that i've plugged into the truck which is a 2018 ford f150 2.7 ecoboost. says vehicle is not supported update required. so i go update the i3 using update agent it says its update complete. go back to the truck try loading again and get the vehicle is not supported message and update may be required again. try updating again and notice its failing to load 2 files. i3 is unlocked. attached picture of screen file issue screen. Any help would be appreciated. thanks
Can you please attach the current info.xml file from the i3 drive?
561-908-0040x4
yeah sure thing here is the file you asked for.
Im not showing any unsupported requests there. That said the last connected calibration is not one we support.
Can you confirm ths is the VIN of the 2.7 you were trying to tune?
-<last-connected vin="1FTEW1EPXJKE20435
561-908-0040x4
Yes that is the vin number for the truck. it is a 2018 2.7l ecoboost 4x4 xlt sport.
1FTEW1EPXJKE20435
make sure ignition is in RUN mode and try again then post a new info file please.
561-908-0040x4
Ok here is the new info file.
Any update? i tried updating the i3 again after you had me plug into vehicle to get new info file and it did load 2 new files. but im still getting same message
sorry, forgot to reply here.
Waiting for an update from the calibration team, you'll get an email as soon as it is ready.
Thanks!
561-908-0040x4
All set, please update then you can tune the truck.
561-908-0040x4
Return to i2/i3 for Ford vehicles
